RE: Spread Spectrum Compatibility With Old Buddy Boxes
CG,
Theres a throttle recovery feature available on the DX7. You have to activate it for each airplane then the box will remember where your throttle trim setting was before you trimmed down for engine shutdown. Just bump the throttle trim switch one click, and it will reset your idle setting. You can do this just after shutting down or when you turn the TX on for the next flight works either way.
