RE: Wing/Fuselage Joint
I tape 80 grit paper to wing overlapping fuse wing area by about 4" each side. Then slide the wing very carefully side to side until you get a good fit. Not all designs will work with this method, but it is the easiest if possible. Another way is to use carbon paper and move wing slightly to get a mark on high spots, then sand using the trial and error method, not a lot of fun.
