RCU Forums - View Single Post - Head temp.
Thread: Head temp.
Old 05-12-2008 | 07:25 AM
HighPlains
Default RE: Head temp.
You will hear the engine lean out as you pull through the turns and then richen up in the straight.
If this is happening, then your tank is too low. If you can't raise the tank, then the engine needs to be rotated to lower the carb.
