RCU Forums - View Single Post - Screwed up - need advice
Old 05-12-2008 | 08:20 AM
r2champion's Avatar
r2champion
Default RE: Screwed up - need advice
If you glued the torque rods to the ailerons using epoxy, try a heat gun to heat the area. Sometimes this is effective in softening the glue and making the removal easier. If you used CA here, it should be easy to break the bond and pull them out.
