ORIGINAL: MinnFlyer
You can do one of two things. Either loosen the collar that holds the nose wheel and make it longer, or bend the mains out a little to lower the rear
I just called my LHS; he's gonna help me straighten it out. I I tried pulling it down a little but then the spring hit the fuse when I tried to turn. I'll use bending the mains as a last resort. It makes sense that this would cause a problem, but I can't believe it could have made THAT much of a difference...
