RCU Forums - View Single Post - G-38 Carb Replacement
Old 05-12-2008 | 11:36 AM
Hogrider's Avatar
Hogrider
My Feedback: (392)
Default RE: G-38 Carb Replacement
Hi Rick,
You may want check on inter-changability.
If your G38 has the skinny iron prop hub, i don't think the carbs can be switched because the small holes may not line-up between the newer WT 338 and the old style G38 carb flange. It will bolt on, but the small holes may not line-up. The newer style G38 has the larger aluminum prop hub with the WT 338 carb.
