RCU Forums - View Single Post - Nitro Planes Bobcat
Old 05-12-2008 | 04:45 PM
opjose's Avatar
opjose
Default RE: Nitro Planes Bobcat
ORIGINAL: caiman
UpJose,
Did you programed any spoileron-elevator mixing on your radio? Do you have 1/4" or 1/8" of travel on your spoilerons?
We have a runway lenght of aprox. 400ft at an elevation of 1600ft over sea level, do you think it will be enough for landing?
How much positive angle of attack should it have on the ground (is it noticeable by sight)?
Thanks.
I have somewhere between 1/4" and 1/8" spoilerons, more is not needed. Each aileron is on a seperate channel on my JR.
I also have the front gear mixed to the rudder and on a switch. When I drop the landing gear for landing, the nose servo becomes active.
That way, I can use the rudders in flight w/o using current on the nose servo.
I also toyed with the idea of putting each rudder on a seperate channel so I could program in an air brake.
When I modeled this in G3, the plane became unstable, as the angle of the rudder pushes down HARD on the tail when the rudders are engaged as brakes.
We have a paved runway length of 500ft and we are at 240ft above sea level.
My Bobcat uses the WHOLE length of the runway to slow down w/o spoilerons, after landing just after the threashold.
With the spoilerons it uses slightly more than half of this...
You want about 2 degrees postitive ( nose up ) angle of attack on the wings as the plane sits on the ground. Yes it should be noticiable.
