ORIGINAL: bruce88123
Couldn't find that but did find:
MASTER
The transmitter can be used as a master but the slave transmitter must have the same programming (i.e. reverse,
travel adjust, dual rates, mixes, sub trims, etc.) as the master.
This tells me the Quatro can NOT be used. Hopefully someone will point out that I am wrong. Good luck.
I hope there will be a simple answer. This is the first time I have seen a computer radio that requires another computer radio, programmed the same, to buddy box with. If this is true it will be very difficult for alot of new pilots to get hooked up with an instructor.
