RCU Forums - View Single Post - Spread Spectrum Compatibility With Old Buddy Boxes
Old 05-12-2008 | 07:35 PM
  #32
KenWh
Default RE: Spread Spectrum Compatibility With Old Buddy Boxes
ORIGINAL: bruce88123
Couldn't find that but did find:
MASTER
The transmitter can be used as a master but the slave transmitter must have the same programming (i.e. reverse,
travel adjust, dual rates, mixes, sub trims, etc.) as the master.
This tells me the Quatro can NOT be used. Hopefully someone will point out that I am wrong. Good luck.
I had always been led to believe that the programming had to match, so that when the trainer switch is pulled, the controls don't go crazy. I didn't guess that it would prevent any function whatsoever.
Which of course leads to the question: Which transmitters have the same programming as the DX6i, and can therefore be used as a slave? Only another DX6i, DX7, and a few JRs?
