RCU Forums - View Single Post - Coleman fuel
Thread: Coleman fuel
Old 05-12-2008 | 11:14 PM
wswanepoel
Default RE: Coleman fuel
ORIGINAL: pe reivers
Disregard the advice of BChi please.
If it is low smell, or a smell that is not objective you're after, Aspen is the only solution. It is a high grade alcylate fuel without the stink, and about the power of gasoline. It has 94 pump octane which is right for all engines I know, except super racers with 1:12 compression ratios.
Hi Pe
Thanks for this advice. Do you know what Aspen is used for in normal life so that I can try to find it here in Kuwait?
