RE: Help? Phoenix Models 63" Yak-54
Spacey another question for you. I finished building the Yak today and was setting up throws as per manual and I have a question on the elevator travel. It says for low rates 12mm but for high rates 16mm???? With the aileron and rudder the difference between low and high rates is quite large, but it seems for elevator this amount is very small?
Maybe my manual is misprinted. Can you remember what throws you had set for hi and lo rates on elev??
Thanks in advance
Scotty
