RCU Forums - View Single Post - Breaking in a new engine
Old 05-13-2008 | 10:57 AM
opjose's Avatar
opjose
Default RE: Breaking in a new engine
ORIGINAL: yetti831
I never had a fuel line problem.
In your other threads what you described seemed to be caused by an initial fuel line problem, then by changing the needles, you ended up with a new hard to tune engine.
If the needles are left alone on the T.H. it will start up right out of the box. You can run a couple of tanks through it as it comes then start tuning it.
I've done many this way. The only time I've had problems is when I did not follow this proceedure.
Usually it's start, run a few tanks, tune and fly with them.
They are not bad at all.
