ORIGINAL: KI8FR
I just got my cap 232 all set and ready to go. I put it on the scale and found out that the plane is 15lbs 4oz. It has 1032" to the wing wich come out to be about 32oz per square. I do not do 3D I just like to fly. How well do you think this plane will do?
Paul
Built it from scratch eh? Cool! I'd like to see some pictures! Do you have any assembly pictures?
What equipment are you using? Maybe we can help you shed some weight.
3lbs over is quite a bit. Is that with or without fuel?
I suppose you use the stock ignition? A magneto? You might be able to do some cutting on the engine and reduce weight. One idea that comes to mind is a chainsaw engine has enough cooling surface so that it can be run under load with little or no airflow. I expect airflow won't be a problem on an airplane so maybe you could shave some material there. Also the cast motor could probably have all the flashing removed, maybe an ounce savings?
Is there any lead in the plane for balance?
What size tank?
