RCU Forums - View Single Post - Fuji-Imvac 50EIS low rpm's?
Old 05-13-2008 | 02:33 PM
Pilot013
Default Fuji-Imvac 50EIS low rpm's?
Hi dear colleagues!
I have a Fuji 50 EIS and I am running a 22x8 prop on it. It turns it at 6450 rpm. I think for this engine is very good. However my GP Yak-54 even at lowest throttle flies with a constant low speed, so the landings are a bit difficult. When I saw on the tach the low rpm's were 1920. I think they are high. Also I tried to reduce them but the engine hesitates and most often stops if they go below 1800. I read that the Da-50 can make 900-950 rpm, which is amazing for me. I don't believe the difference is so big. Maybe there should be some tip or tunning trick to make the engine more stable at lower rpm and also to reduce them so I land easier.
Waiting for your answer and suggestions!
Best regards!
