RE: Extreme Flight Extra 58"
Welcome Insalacom! Good to see you over here. This is flyinghigh off RCG .
SDS
Yeah when I had the dead stick the landing gear folded back and the engine mount broke. Id rather the mount break then the box or the firewall though.
I can get another in the glow conversion kit . Wish they sold it seperate . All that should be here this week maybe. Landing gear is halfway repaired ,I just have to
dremel out one of the ends of the rod from the firewall and reaplace with new. They cam out pretty easy so Im sure they are not glued in too good.
I had the engine too lean and just should have stayed on the ground my fault and lesson learned!
Thanks for all the advice also !
Mike
