Originally posted by WoodsyMatt
Thanks for the links. I have actually been to Zinger's site and saw that very page. I have read that if you use a 3-blade prop over a 2-blade that you need to reduce the diameter by an inch. The .25's use a 9x6 typically, so that would imply a 3-blade 8x6. I wonder if the 10x4 that zinger makes would be usable. By thrust alone, the 10x4 makes less thrust than a 9x6. What do you think?
sounds like it makes sense but, I don't know, i'm not an prop guru. maybe you can find that info elsewhere on RCU.
As far as cost goes for the props i don't know yet but it will be substancial as he is custom deigning them for me. Normally he makes fullsize woods props on his cnc table. All i wanted is to be able to show up at the field and not have to change from static to flying props. but none were available with the sqaure blade design.
Grinder.
