SIG 1/5 scale cub
Putting together the second (right) wing I have noticed that I have made a mistake on the leading edge of the first wing I built (left). I failed to trim down the leading edge sheet so ithe trailing edge would rest halfway along the main spar. Instead, I simply glued in the entire 3" sheet which overshoots the main spar approx. .50 inches or so. I ignorantly went ahead and finished the wing (including installing all the rib cap strips etc.), and did not notice this mistake until I started building the second wing. My question is this: Will it be OK to simply build the other wing the same way? The only trouble I can imagine is a small amount of extra weight (I figure very nominal). Being new to this I wanted to appeal to someone who may know this model and whether their are any future problems that I can't anticipate. Thanks for any help you may offer, Pete[/size]
