RE: Nitro Planes Bobcat
Hi again OpJose,
I just wanted to double check with you where should the ailerons and rudder travel should be measured (according to the instructions travel), on the widest or on the narrowest part of each control surface?
Also, as per your previous comments, I know that the elevator central position should be measured on top of the stabilizer instead of the bottom, but what about the aileron central position? should I make the ailerons level with the lower or the upper part of the wing?
Finally, this is my first pusher airplane, how much should I enrich the mixture of my OS 55AX so it won't overheat?
Any other flying tips you could give me?
Thanks.
