Evolution 46 Stalls in turns.
I bought the hangar 9 T___T (Twist) ABOUT a week ago, this is not my first plane not even close but for some reason I can't get it to run correctly, it will idle fine, the pinch test is a little off, after pinching the fuel line the motor runs for a about 60 seconds, but if i try to lean it out, when i go to full throttle it sputters and dies, and if it doesnt die then it doesnt even come close to making full power. I have tried the nose up test but everything seems ok, one thing i noticed is that if i actually get if off the ground it will fly fine but in a hard turn the motor cuts out and stalls or comes close to it. can anyone help i have never had this much trouble with tuning.
