RE: Evolution 46 Stalls in turns.
It's too lean. If you are proficient in tuning a motor, then you need to look for other problems. Have you pressure tested your fuel tank? Try that as well as changing all your fuel lines (even the one inside the tank). You may have a small air leak somewhere.
