TX DAMAGED NOW, WHY????
I was using my TX to install and adjust servos in my Vista sailplane when all of a sudden the elevator stick loosened up and will not return to neutral on its own. The TX still works but you have to return it to neutral manually, and I will not fly any plane or glider in that manner.
So now, before beginning to learn to fly I have to replace my TX. I thought Futaba was better quality than that, anyone have any disconcerning words to say about Futaba? Should I replace it with another Futaba or does anyone know if Tower Hobbies brand is better?
It is a Skysport, and the replacement TX has to be compatible to all the Futaba gear I have.
Could have been worse, coulda been in the air when it broke.
