RCU Forums - View Single Post - TX DAMAGED NOW, WHY????
Old 05-13-2008 | 11:25 PM
shd3920
Default RE: TX DAMAGED NOW, WHY????
ORIGINAL: RCKen
Does the stick move normally?? Are you saying that it won't return to center otherwise???
Yes it works normal but say when I move the stick down the servo moves fine but the stick remains down when I let go of it, it does not return to neutral.
If this is the case it sounds like the centering spring for that stick as come off. Carefully remove the back of the radio and see if the spring is missing.
If you are correct and it is the spring can it be replaced/repaired easily, especially for a novice?
If you haven't used this radio yet it must still be new right??? You should be able to have Futaba take care of it under warrenty if it's anything more than the spring coming off.
Haven't been used for flying yet but it is well over a year old.
