RCU Forums - View Single Post - Mini Pulse ?
Thread: Mini Pulse ?
Old 05-14-2008 | 11:58 AM
opjose's Avatar
opjose
Default RE: Mini Pulse ?
ORIGINAL: dbgood
Ok one more question...I have the eflite 450,will the efilte 480 910kv,have more speed and torque then the 450...Thank you very much for all the help...
Danny
Yes as long as you prop the motor properly.
The 480 can sustain higher current draw w/o building up heat. You have to prop the motor to get the right power input.
Were you to use the prop for the 450 on the 480, and the KV rating is the same, you would find that the performance would be identical.
However the 480 can tolerate a bigger and/or higher pitch prop, producing more wattage...
