RCU Forums - View Single Post - blade cx range problem
Old 05-14-2008 | 12:46 PM
nomobux's Avatar
nomobux
Default RE: blade cx range problem
ORIGINAL: DRAGONFIRE81M
hey guys i have a blade cx ever sence i got it its had bad range like 30ft is max if you go out of that box she'll drop like a rock . and if you hold the radio down its even worse . it has a new 4in 1 and cystal set .im thanking theres something wrong with the radio . any help would be great .
The basic checks are, batts good ?, all plugs tight ? Ck the manual, there are dip switches on the TX. Make sure they are in the correct position. Double ck the manual for set up and do a good range check before you fly. The dips are if you have the Spektrum tX
