ORIGINAL: riadh
Thank you gentlemen.What cutoff voltage I need to set for discharge cycle;. 0.9 or 1.1 V per cell?Battery packs I use are 4.8V Sanyo AA NiCad and Hydrimax 2000mAh NiMH.Do they stand 1C charging rate?cheers
Everything I have ever read is 1.1v per cell minimum voltage, you might try the RCbattery clinic (
www.rcbatteryclinic.com I think) for more info.
I personally never charge my 2700mAh NiMH RX pack at over 1 amp, 1C would be 2.7 amps but Im just paranoid. (Actually usually dont go over 600mA LOL But lower rates are easier on the packs and I dont need it charged THAT fast.)
I also do not have a cycler YET.. I intend to build a discharger circuit that will bring them to 1.1V per cell, but havent done it yet.
