RCU Forums - View Single Post - TX DAMAGED NOW, WHY????
Old 05-14-2008 | 04:04 PM
bruce88123
Default RE: TX DAMAGED NOW, WHY????
ORIGINAL: Villa
Hi shd3920
Is it possible that what you are calling the elevator stick is actually the throttle stick? On the vast majority of the radios we use, the elevator is on the right side of the radio, moves forward and backward, and is spring loaded to return to neutral. The throttle is on the left, moves forward and backward, and is not spring loaded to return to neutral. It clicks as it is moved. This system is called by a number, I believe, but I cannot recall what it is. In the other system, the right and left sticks are reversed, but I am not familiar enough with this feature to offer any correct information. I do recall reading that on some radios, one system can be converted to the other. Let me know.
You're referring to the difference between Mode 1 and Mode 2 (Modes 3 & 4 also available). When switching between mode 1 and Mode 2 the ONLY functions that differ are the Elevator and Throttle. Ailerons and Rudder are the same.
