RCU Forums - View Single Post - RC18T Steel Diff and Input gears Yes/No
Old 05-14-2008 | 10:50 PM
  #55
calvino's Avatar
calvino
Default RE: RC18T Steel Diff and Input gears Yes/No
ORIGINAL: pinoyboy
ORIGINAL: rawvoodoo
thank you gex that was incredibly informative. Exactly what I wanted to know. Will the exotek slipper work with the dp spur cover? If not will the exotek spur cover work on a regular rc18t ft and will it work with the slipper?
It would seem easier to modify the DP gear cover with the Exotek slipper since its only made of polycarb and is made for the stock RC18T/B/R chassis. The exotek gear cover is alloy and is not made for the stock RC18T/B/R chassis
the Exotek gear cover is made JUST for their rear pack conversion kit, sadly not for the "stock" 18 line, hope DP comes out with one that works[8D]
