RCU Forums - View Single Post - brake cleaner
Old 05-15-2008 | 02:22 AM
ahawk65's Avatar
ahawk65
Default RE: brake cleaner
I can't see any reason why it would. Try either spraying or dabbing a bit of the product you are using on an unnoticeable part of your pipe (on the underside of the belly, under the stinger, on the bottom of the manifold, etc.), let it dry, and take a look. Good luck, and congratulations on your new pipe! Post some pictures if you have any. =)
