Set your trims and switches as if you want to shut down the turbine.
Then go into the FS menu, and activate FS on the throttle, then hold down the rotary push button, and it stores the throttle off position.
Plug in the hand terminal in the ECU, and turn off the TX, and see it says trim low......just to test it
