RE: Glitching?
Unfortunately you could rebuild and it be fine... You might fix the problem and never realize what it was... The most common bearings to produce RF are the clutch ones as they are spinning at a higher rate and they often dry out due t othe engine heat. BUT that's not saying it is these bearings or that it is even a bearing.
I would rebuild, put in a DX7 full range radio and try it again...
