RCU Forums - View Single Post - Whats been the biggest effect of 2.4 ghz
Old 05-15-2008 | 11:53 AM
PipeMajor
Default RE: Whats been the biggest effect of 2.4 ghz
[ul][*] It "should" end the inadvertant shoot-down[*] It "should" end the problem of having the wrong model selected (Spectrum model-match feature)[*] It eliminates having to route the 39" antenna externally[*] It "did" make all the existing 72MHz gear much less expensive[*] It will "likely" do to the 72MHz equipment what Compact Disks did to the vinyl LP market 20 years ago
[/ul]
