ORIGINAL: kajabbi
So basically is a drive dog a connector that converts a 4mm shaft head into various sizes so that you can fit other props? anyway
your help. :-)
Cheers, Conor
Sort of..., your 4mm threaded shaft will take all (Graupner) props with M4 thread, obviously.
As not all sizes come with M4 thread, you can use a drive dog to be able to use all other props, fitting that drive dog (specially the metal props are mostly drive dog).
Regards, Jan.
