120NC Carb Modification?
Dave,
Mine already has a hole in it. Does it come form the factory with an air bleed hole. I am not sure what size it is, but I doesn't look like it is 1/8". Should I drill it out. Mine has the typical "burping" idle now, but doesn't seem to load up like some others. I could use a lower idle if possible.
Thanks for your help.
Mark
