RCU Forums - View Single Post - G-38 Carb Replacement
Old 05-15-2008 | 03:49 PM
AIRPLANENUTS
Default RE: G-38 Carb Replacement
Thank you, King. Is that the WT-540 carb? Your job looks good to me.
I'm not sure when my G-38 was manufactured, but I did find that it has the aluminum prop shaft, and the WTA6A carb w/no choke.
I found a useful article, both in terms of carb replacement and ignition conversion. Looks like the WT-540 is a bolt-on fit:
http://tech.flygsw.org/g38ignition.htm
The WT-540 is the way I wanna go, as I like the auto choke shutoff and large bore.
