RCU Forums - View Single Post - Servos move to full throw when switch on
Old 05-16-2008 | 01:52 AM
In the Haze's Avatar
In the Haze
Default RE: Servos move to full throw when switch on
ORIGINAL: BaldEagel
Guys
I don't know if it applies to the Futaba, but with the Spektrum module in my Zap it was caused by not rebinding after setting controls ATV and fail safe, once I did a rebind the problem went away, hope this helps.
Mike
Yes been there on Spektrum, stripped 2 flap servos before we worked it out.[:@]
Re-linked the Futaba receiver but makes no difference. I have put in a powerbox digi switch to regulate the power to 5.5V as I am using a 6 volt pack and thought the fully charged pack providing at least 7 volts initially was the problem. No change.[&o]
Next is to pull out the turbine ECU and Aux plug from the receiver to see if that's the problem, can't see it but may as well try everything possible I suppose.
My other planes do not do this by the way, so that is why I am thinking it may have something to do with the turbine, but as I say I don't really think so.
