RCU Forums - View Single Post - electronics hook up questions.
Old 05-16-2008 | 10:24 AM
wackywheelz's Avatar
wackywheelz
Default RE: electronics hook up questions.
Is your smoker normal (two wires with a white plug) or proportional (2 wires to a white plug, 2 sets of 2 wires with bare ends)
If its a normal non-prop smoker, simply connect it with a switch (so you can shut it off), to the battery.
If proportional, the plug end needs snipping off and wiring to the battery (again, with a switch) and the other 2 sets of 2 go to each motor (for "sense" of how much smoke to produce)
