RCU Forums - View Single Post - CMP Zero Makeover
Old 05-16-2008 | 07:08 PM
  #151
fishdeth's Avatar
fishdeth
Default RE: CMP Zero Makeover
ORIGINAL: Baron243
Since I had some 12” 22ga Futaba servo leads on hand, I decided to convert 4 of the HD220A servos over to the heavier leads. Note: You will definitely need a low wattage pencil type soldering iron with a fine tip. It wasn’t too difficult, as I was able to do a credible job by hand on the first one, but since I had potentially 9 more to change I decided to make a simple jig to do the others. If anyone is interested, I’ll try to post pictures and a drawing of the jig. The jig definitely makes the process easier. It occurs to me that there is an added benefit to doing this; as you can now make the servo lead any length that you want, there by eliminating one connection and its associated voltage drop!
(More delivered voltage = more power.)
Robert
I would love to see the jig and pics !
Jim
