RE: "OFFICIAL" Redcat Lighting VX Thread
Pull the engine out CobyZ and then remove the 2 speed clutch bell and check the clutch that is underneath the clutch bell. If the clutch is ok, then check the 2 spur gears on the 2 speed transmission and make sure those are ok as well. Don't worry about breaking anything as the Lightning is pretty easy to work with and put back together if you pay attention to what you are doing.
