RCU Forums - View Single Post - Voltwatch, you all use 'em?
Old 05-17-2008 | 07:04 AM
  #140
Missileman's Avatar
Missileman
Default RE: Voltwatch, you all use 'em?
ORIGINAL: panzerd18
I have a JR 4.8v 1100mah Nicad pack, 4.8v 2500mah Nimh pack and a 4.8v 2000mah. I have only used the JR RX pack of 1100mah and have been able to get a full days flying (5 or so flights) no problems. I think if I had a 600mah pack I would be getting worried. So my answer is to get a big capacity RX battery pack and you can insure if you charge the batteries with a peak detection charger the night before you will have no problems.
Not always true. Yes high capacity batteries usually mean a full day of flying but a battery pack can fail at any time fully charged or not. Vibration and what not can cause a weld joint in the pack to fail or one of the cells can go bad. You should always check your battery before flying no matter how much the capacity is.
