RE: Voltwatch, you all use 'em?
True but if the battery is going to fail due to vibration then thats the risk I will take. It will probably fail when you are flying and there is nothing you can do once its in the air. On a 4.8 volt system, if one cell fails will it cause a total loss of controls as the voltage to the RX will be too low?
