RCU Forums - View Single Post - Brillelli 46 issue
Old 05-17-2008 | 08:00 AM
bigben
My Feedback: (24)
Default RE: Brillelli 46 issue
I'd swap carbs if you are lucky enough to have two of the same and see what you get. In doing so will help you sort out whether or not it is a carb issue or mixture issue. I assume compression feels good?
Good luck, you'll sort it out and I know Scott will be there if you need him.
