RE: Brass clunk in gas fuel.
If you think the brass clunk is causing the crud, try using a nickle or chrome plated one instead of an expensive felt clunk.
Or cheaper yet, use a long curved copper or brass tube, same as your other tubes used for the vent and carb feed tubes, aimed at the bottom of the tank.
