RCU Forums - View Single Post - New Engine head loose
Old 05-18-2008 | 02:01 AM
djay
Default RE: New Engine head loose
My 51 was the same, it would only run at full throttle. I reassembled the carb correctly and then noticed a lot of oil coming from the head, all the head bolts were less then finger tight.
Tightened them up and she runs lovely, but it will not shut off at idle, suspect an air leak around the mounting lug area.
