servo alignment
Hi.
Ive read loads of threads on servo alignment but not 100% sure if you make the servos 90degrees with the servo arm to the case of the servo or if you make it 90 degrees to the push rod that leads to the swash plate with the screew at the centre of the servo.
Thanks for clarifying this for me.
