RCU Forums - View Single Post - Sig Smith Miniplane build
Old 05-18-2008 | 10:12 AM
  #173
EF
Default RE: Sig Smith Miniplane build
I strongly recommend you do not change those elements of the construction.
They are desigend correctly for their intended purpose and the model's size, weight, and flying speeds.
They are not over or under designed at all.
Weight can be saved by ensuring perfect joints so you do not build up glue fillets and unnecessary weight, and by going easy on the finish.
I would not change anything else.
