Yeah, the Deans connectors worked flawlessly. I had them on all my batteries even before starting out, some experience buddies suggested I switch thosr bullet plugs and it was good advice.
The only problem occurs with deans is when too much dirt gets onto the connections, there's probably some inteference which causes carbon built up. When that happens the deans connectors gets hot during & after runs, which will be time to scrap & clean those connections.
* Correct me if I'm wrong. I'm new.
