ORIGINAL: Bob Pastorello
Another GREAT report! Thank you!
What oil ratio are you currently using?
Do you have the static port on the carb tube-connected behind the firewall? It looks to point dead ahead; wondering if that needs minding?
Standoffs?
Stock mufflers?
Good questions...
I have it running on "broke in" gas now; that's regular mixed with Amsoil Saber Professional mixed at 85:1.
I purposely left the static ports exposed to see if there would be any problem and I haven't noticed any. I plan to install isolators (soon I hope), to see if they have any effect.
No stand offs were used in my application. The mount to prop hub distance is 6.6in. so spacing may be required on some installations though.
Stock mufflers are installed. On the quiet scale they register "not".
Regards,
Bob
www.dlusa.net
