RCU Forums - View Single Post - DX7 programming max throws?
Old 05-18-2008 | 06:47 PM
khodges
Default RE: DX7 programming max throws?
When you select the respective channel to program, move the stick to one side and it will allow end point adjustment in that direction, Move it to the other side, and you can set the end point in the other direction. You will see the throw percentage light up on the display for the direction you are setting. You have to do both channels the same to get equal throw on both surfaces.
