RE: Right Thrust
Avalanche2, You have already received a lot of good information, however here is a bit of background info. that may help you analyze whatever you might need.
Look at your head-on pic. Your engine is NOT mounted on the centerline of the fuse but just a bit off center. So every time you make a throttle change the model either receives (fast T) or loses (low T) a tendancy to turn left its left as seen from the pilot's station as 'pmw' so stated. The prop turns CCW as we look at it for starting but it's CW when sitting behind it.
Many new 1:1 scale pilots really get a shock when they start multi-engine training and find what happens when they lose an engine on one side and just how much rudder can make a difference. Ailerons with resulting induced drag only complicate the problem. Engines way out are truly a handful while even those with so called Center-Line thrust (engines close to fuse. or mounted on fuse) will require almost full rudder application against the dead engine to maintain heading when an engine fails on take-off at or just prior to T.O. speed. During landing, engine-out, you are constantly adjusting the rudder trim as you change power on the good engine.s and/or airspeeds during the approach phase.
Now since you with your RC model have no need to constantly adjust rudder trim every time you adjust throttle, the thrust-line adjustment will do it for you. Power back, no pull, Power up, the added power pulls right counteracting the left turn-in to assist you to maintain heading. When you learned RC maybe you had a trainer with engine downthrust. That is what downthrust does: counteracts the high-throttle acceleration which creates lift that requires something, elevator or downthrust, to counteract the effect of lift which increases by the square of increasing speed. If you just trim the elevator down, then when you pull the power back, hey it's dive time. [X(]
Yes that very small off C-L will make a difference. When combined with all those things the elites love to argue about, the machine, she is a-gonna turn left. [sm=50_50.gif] Engine offset is the answer. Shaved hard plastic beats washers because washers creep into the wood loosening your engine and mussing your fine paint job.
Edited to add: RC pilots have problems with multi-engine-out because they cannot quickly see which way the aircraft yaws, only a wing drop and generally apply significant aileron complecating the problem even more.
Go get 'em and keep it straight.
