If you dont wanna grab a temp gauge then just let it cool off for ten mins after each tank you run,we do the same with elecy after a full battery to let the motor cool off before running another pack like said drifting doesnt use much traction so the temps on the motor are usually high after a good run,so give yourself 5-10mins between each run i use that time to set up the drift course anyway so it saves sitting around waiting
